Grahamerin
Apr 29, 2020Initiate
Orbi RBK50 to TPG FTTC connection
Hi, We purchased an Orbi RBK50 and had an issue connecting to the internet via our TPG FTTC modem. We followed the advice in the discussion group and logged into the Orbi from an internet browsers ra...
Apr 29, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Grahamerin wrote:
Hi,
We purchased an Orbi RBK50 and had an issue connecting to the internet via our TPG FTTC modem. We followed the advice in the discussion group and logged into the Orbi from an internet browsers rather than through the app. We went to advanced setup and enabled and changed the VLAN ID to 2 via VLAN/bridge setting “by bridge group” and chose port 1. This made the internet connection work but now one of the Ethernet ports on the back of the Orbi will not work. Any suggestions as we would like to plug in 3 devices via the ports?
Thanks
Grahamerin
Apr 30, 2020Initiate
FURRYe38 Retired_Member
Thanks for your replies.
The NBN modem is a NetCommWireless FTTC Network Connection Device model NDD-0300
Will configuring the modem for transparent bridge or modem only mode fix the Ethernet ports on the NG router?
Thanks
- AnonymousMay 01, 2020
Grahamerin wrote:FURRYe38 Retired_Member
Thanks
Thank you:smileyhappy:
- FURRYe38May 01, 2020Guru - Experienced User
Configuring Transparent or Bridge mode will help with NAT issue between the ISP modem and the RBR.
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATTransparent or bridge mode is preferred on the ISP modem.
Grahamerin wrote:Thanks for your replies.
Thanks
