Mdkart
Apr 06, 2018Tutor
Orbi RBK50 total failure (ring led blink white)
Hello, I need some help. My netgear orbi router rbk50 led ring blinks white this evening. The router doesn't works at all (either on wire or wireless connection). Seems it's a total failure. I've tr...
Mdkart
Apr 07, 2018Tutor
Just for information , here is the sequence that the reset button does when I press it and power the orbi then : Green fix (~5s)> Red fix (~5s) > Red flash (~3s) > Green Fix (~20s) > Red flash (~3s) > Green Fix
