Mdkart
Apr 06, 2018Tutor
Orbi RBK50 total failure (ring led blink white)
Hello, I need some help. My netgear orbi router rbk50 led ring blinks white this evening. The router doesn't works at all (either on wire or wireless connection). Seems it's a total failure. I've tr...
Mdkart
Apr 07, 2018Tutor
Tried with the native Windows tftp client and can't connect to the router to push the firmware (what I thought before as I can't ping int neither)
Try to contact the support
Apr 07, 2018Guru - Experienced User
Let us know how it turns out.
Good Luck.
- MdkartApr 08, 2018Tutor
For sure.
I will contact the Netgear support tomorrow and let you know.
Thank you
- FURRYe38Apr 08, 2018Guru - Experienced User
Good Luck.
- MdkartApr 09, 2018Tutor
I have contacted the support today. They made me do some tests with the reset button. Then they sent me the instructions for the tftp firmware update.
It didn't work.
They told me they will contact me soon after they will have the engineer's opinion.
