Mdkart
Apr 06, 2018Tutor
Orbi RBK50 total failure (ring led blink white)
Hello, I need some help. My netgear orbi router rbk50 led ring blinks white this evening. The router doesn't works at all (either on wire or wireless connection). Seems it's a total failure. I've tr...
Apr 07, 2018Guru - Experienced User
Let us know how it turns out.
Good Luck.
Mdkart
Apr 08, 2018Tutor
For sure.
I will contact the Netgear support tomorrow and let you know.
Thank you
- FURRYe38Apr 08, 2018Guru - Experienced User
Good Luck.
- MdkartApr 09, 2018Tutor
I have contacted the support today. They made me do some tests with the reset button. Then they sent me the instructions for the tftp firmware update.
It didn't work.
They told me they will contact me soon after they will have the engineer's opinion.
- FURRYe38Apr 09, 2018Guru - Experienced User
Good to hear. Hope they will get you an RMA. Sorry the recovery didn't work out.
Keep us posted.
