Mdkart
Apr 06, 2018Tutor
Orbi RBK50 total failure (ring led blink white)
Hello, I need some help. My netgear orbi router rbk50 led ring blinks white this evening. The router doesn't works at all (either on wire or wireless connection). Seems it's a total failure. I've tr...
borwornsuk
Apr 10, 2018Aspirant
I think I'm having the same problem as this case.
At first, My devices couldn't connect to wifi which used to work smothly. I found out that my Router couldn't find the Satellite, so I tried to reset by pressing the reset button at the back (first time only 1 click) on both devices.
Then I tried to set everything up from the begining using Orbi App in iOS as I did in the first time. The wifi doesn't seem to be stable (unable to join, incorrect password) and even I could connect to the wifi then it will be disconnected after few second.
After that I switched to my PC setting up the router by LAN instead of Wifi. Then I was strucked since the Router coun't find the Satellite. Even I moved it so close to the Router, there was still magenta light on it.
I did the hard reset once again with longer press (1 mins) as read from this community but nothing change. So once you got the exact solution please help update to this forum.
- FURRYe38Apr 10, 2018Guru - Experienced User
Are you have a RED LED blink on the router?
What model Orbi system do you have?
What FW is currently loaded?
How big is your home? SqFt?
How far appart is the router from the Satellite?
Set the router using a wired connected PC or laptop instead of the orbi app.
Any other wifi neighbors near by? If so, how many?
What channels are you using on the router?
borwornsuk wrote:I think I'm having the same problem as this case.
I did the hard reset once again with longer press (1 mins) as read from this community but nothing change. So once you got the exact solution please help update to this forum.- borwornsukApr 11, 2018Aspirant
> Top LED ring blinking white. Power LED is now green.
> RBS50 — Orbi AC3000 Tri-band WiFi System
> 2.1.3.4 but it used to be 2.0.1.4 before I tried to manually install the FW to it
I'm not sure about FW of the satellite since I was unable to pair the satellite.
> It was function well for more than 4 months. My home has 2 floors. Aprx 1400 sq.ft. for each floor.
> Before having problem, my router is on the 2nd floor and the Satellite on the 1st, around 30 ft from each other.
> First use was set by Orbi app. But since I was disconnected everytime I tried to find Satellite, I used wired connect to PC instead but I didn't work so far.
> 3 neighbors' Wifi near by around 30-60m. from the router
> What channels?
- FURRYe38Apr 11, 2018Guru - Experienced User
Please made a new thread in the main forum with this information and we'll help you out. This isn't realted to this post and lets not confuse the two. This users router has to be replaced. Yours is a different issue.
borwornsuk wrote:Are you have a RED LED blink on the router?
> What channels?
