tomulsh
Nov 15, 2020Aspirant
ORBI rbk50 USB port // Wired printer connection through NETGEAR USB Control Center not visible
My Netgear system is an RBK50 (RBR50 with 2 RBS50 satellites). - I am attempting to setup a printer through my network using the USB port and the ReadyShare Printer service. - My printer is a Canon...
Nov 16, 2020Guru - Experienced User
Your printer has wireless support. Review the printers user manual on how to connect the printer via wireless.
tomulsh wrote:My Netgear system is an RBK50 (RBR50 with 2 RBS50 satellites).
- My printer is a Canon PIXMA TS6120. The printer driver is current with the latest version.
- I followed the instructions shown in my router's menu tab "BASIC" > "ReadySHARE Printer. (See Screenshot 1 - upper half)
- I downloaded the NETGEAR USB Control Center utility from www.netgear.com/readyshare. Download was successful.
- I opened the NETGEAR USB Control Center utility. (1) The USB Control Center is completely blank. No system shows up, much less the printer. All the buttons on the bottom of the dialog box are grayed out. (See Screenshot 1 - lower left corner)
>> the OS on my 1st computer is Windows 10
>> the OS on my 2nd computer is Windows 7
Question: How do I use a setup a wired network connection to my printer though my RBR50 router?
