BruDaniell
Apr 17, 2017Aspirant
Orbi RBK50 vs RBR50 Difference
I found the RBR50 selling the two piece set for $269, which is about $100 less than the RBK50 two piece system which makes me suspect there must be a significant difference. Cannot find an article e...
- Apr 17, 2017
Correct. You will not be able to pair two Orbi Routers together to form a system. You need 1 Orbi Router + (1 or more) Satellites. We do sell Stand Alone Orbi Routers and Stand Alone Satellites
loomis1975
Apr 17, 2017Luminary
RBK50 is a kit, one RBR50 Router and one RBS50 Satellite.
RBR50 is just the Router designation, so if its two pieces of RBR50 you are getting two routers. Not very useful together.
AmitR
Apr 17, 2017NETGEAR Employee Retired
