jkcrwdr
May 15, 2018Aspirant
Orbi RBK50 w/ Powerline
Hi all,
I have recently (in the last week) upgraded my family to the Orbi 50 system and it works great. To cut a long story short; we have an office/study at the bottom of the garden where the ...
May 15, 2018Guru - Experienced User
Does the PL work in the same room? I would test this out in the same room first.
PLs can be problematic...
How about adding another Satellite to near this office?
- jkcrwdrMay 15, 2018Aspirant
My parents don't really want to shell out more money for an additional satellite.
I have tried two kinds of PL, one wireless (through a seperate SSID) and the most recent wired, but both don't seem to be chucking me any Internet access. I was wondering (hoping) there was an advanced setting I needed to enable to allow to make this possible, but I guess I'm out of luck in that regard?
- FURRYe38May 15, 2018Guru - Experienced User
Did you try both PLs in the same room to verify same room circuit connetion?
I presume if this also fails, there isn't any configuration I know of.
Might disable Daisy Chain and see if this helps any.
- AC641May 15, 2018Luminary
To be clear, Powerline Adapters are absolutely compatible with the Orbi; I have eight of them around my home without issue. As others have suggested, establish a connection in close proximity and assuming that works move it to your office.
