jkcrwdr
May 15, 2018Aspirant
Orbi RBK50 w/ Powerline
Hi all,
I have recently (in the last week) upgraded my family to the Orbi 50 system and it works great. To cut a long story short; we have an office/study at the bottom of the garden where the ...
May 15, 2018Guru - Experienced User
Does the PL work in the same room? I would test this out in the same room first.
PLs can be problematic...
How about adding another Satellite to near this office?
jkcrwdr
My parents don't really want to shell out more money for an additional satellite.
I have tried two kinds of PL, one wireless (through a seperate SSID) and the most recent wired, but both don't seem to be chucking me any Internet access. I was wondering (hoping) there was an advanced setting I needed to enable to allow to make this possible, but I guess I'm out of luck in that regard?
- FURRYe38May 15, 2018Guru - Experienced User
Did you try both PLs in the same room to verify same room circuit connetion?
I presume if this also fails, there isn't any configuration I know of.
Might disable Daisy Chain and see if this helps any.
- AC641May 15, 2018Luminary
To be clear, Powerline Adapters are absolutely compatible with the Orbi; I have eight of them around my home without issue. As others have suggested, establish a connection in close proximity and assuming that works move it to your office.
- budyMay 15, 2018Luminary
+1 from me - PL adaptors are basically solo units, which present themselves as a bridge on the layer2 and as an IP device on layer 3, there is nothing there, which could interfere with the Orbi. However, be prepared for low performance and high latency…
