jkcrwdr
May 15, 2018Aspirant
Orbi RBK50 w/ Powerline
Hi all,
I have recently (in the last week) upgraded my family to the Orbi 50 system and it works great. To cut a long story short; we have an office/study at the bottom of the garden where the ...
jkcrwdr
FURRYe38 wrote:
Does the PL work in the same room? I would test this out in the same room first.
PLs can be problematic...
How about adding another Satellite to near this office?
My parents don't really want to shell out more money for an additional satellite.
I have tried two kinds of PL, one wireless (through a seperate SSID) and the most recent wired, but both don't seem to be chucking me any Internet access. I was wondering (hoping) there was an advanced setting I needed to enable to allow to make this possible, but I guess I'm out of luck in that regard?
May 15, 2018Guru - Experienced User
Did you try both PLs in the same room to verify same room circuit connetion?
I presume if this also fails, there isn't any configuration I know of.
Might disable Daisy Chain and see if this helps any.
- AC641May 15, 2018Luminary
To be clear, Powerline Adapters are absolutely compatible with the Orbi; I have eight of them around my home without issue. As others have suggested, establish a connection in close proximity and assuming that works move it to your office.
- budyMay 15, 2018Luminary
+1 from me - PL adaptors are basically solo units, which present themselves as a bridge on the layer2 and as an IP device on layer 3, there is nothing there, which could interfere with the Orbi. However, be prepared for low performance and high latency…
- AC641May 16, 2018Luminary
Can you tell us the make and model of your Powerline Adapaters? Have you sync'd them and assigned a password? Have you first got them working in close proximity to prove the connection? How far away from the main house is the garden office?
