borwornsuk
Apr 11, 2018Aspirant
Orbi RBK50 was disconnected from Satellite and couldn't connect again
Hello, I bought Orbi RBK50 around 4-5 months ago and it used to work perfectly until last week. I found out that my devices couldn't connect to wifi which used to work smothly. Because my Ro...
tsig
Apr 12, 2018Luminary
When you upgraded to v2.1.3.4, did you perform a factory reset on both router and satellite then set up from scratch? This needs to be done for this version of FW.
I've seen you say this several times, and it simply isn't true. My system auto updated to the latest version of the firmware on its own and everything has been just fine. It may be a step to take if you have issues, but it certainly isn't a requirement.
Apr 12, 2018Guru - Experienced User
May for you and others, thats fine. Others have said that factory resets have fixes there continued problems with this FW. I have information as well that says it should be done for this version.
Enjoy.
