shafman
Jun 06, 2022Aspirant
Orbi RBK50 white flashing light
Hi, I have seen various posts outlining a similiar problems but the solutions proposed (reboot, reset , firmware download etc.) did not work. For the firmware update, I connected (macos) to O...
KevinLiT
Jun 06, 2022NETGEAR Moderator
Hello shafman,
I understand that you can not connect to your RBK50 system using (macOS). Are you able to connect using the Orbi app?
Best,
Kevin
Community Team
shafman
Hi Kevin,
Thanks for replying.. Unfortunately no. The wifi network that i had setup to access Orbi is not available at the moment.
