lawnmowerman
Mar 18, 2020Guide
Orbi RBK50 WiFi going offline
My Orbi RBK50 wifi connection is constantly going offline, while wired connection stays active. So all my wireless devices suddenly go offline. The only way to fix has been to reboot the router. I ha...
theoak
Mar 18, 2020Luminary
Can you narrow down if the issue started when you upgraded to 2.5.1.8?
There is the standard, reset your satellites and router and reconfigure.
You can also try downgrading to 2.3.5.30 to see if stability returns.
lawnmowerman
Mar 18, 2020Guide
I have been on v2.5.1.8 for over a month, so it did not start with that.
It's not an issue with the Router-Satellite connection, it's all devices losing WiFi suddenly and only a reboot fixes it. This started happening today. Meanwhile, all the wired connections work fine while the wifi is offline.
Is v2.3.5.30 the last stable version for this router and does Circle work with it?
Thanks
- FURRYe38Mar 18, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update? You might try this first. Don't enable Circle just yet. See if anything changes. If it's better, then enable Circle. Others have need bad behavior with Circle.
Please give feedback to the other questions as well.
- lawnmowermanMar 18, 2020Guide
Yes, the factory reset and setup was done after I first updated the firmware to v2.5.1.8. I haven't changed anything since then and everything was working fine.
- FURRYe38Mar 19, 2020Guru - Experienced User
30 feet is too close, it may work for a while, however if something changed then it may stop. Try moving the RBS out to 30 feet or beyond. Having them too close causes too much wifi signal over lap. Noisey signals impact each other. Also try some of the other suggestions.
