Cbernad
Jan 27, 2019Aspirant
Orbi RBK50 WiFi gone wonky
Been working like a dream for quite awhile. Now the WiFi is all jacked up, but wired LAN works perfect. On wifi: - I can use iMessage - cannot access webpages or speedtest.net - cannot access rout...
Jan 27, 2019Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
Be sure the BeamForming and MIMO are enabled.
- CbernadJan 28, 2019Aspirant
The FW is the most current. But I have some new information.
The WiFi connectivity issues seem to be somewhat device specific. Most of the devices are now accessing the internet, but I have one iPhone, one iPad, and a couple of Kindle Fires that are not. Although they show that they are connected to the network, when I go into Genie those devices are not showing up.
- FURRYe38Jan 28, 2019Guru - Experienced User
Please let us know if any of the suggestions help.
Please give feed back to the question presented so we can get a better idea of your configurations.
