gabe618
Mar 03, 2020Aspirant
Orbi RBK50 Wifi on have 250Mbps with a 1Gbps Internet Line
Hi all, Would like to get your help and advice, I have just purchased a RBK50 AC3000 Orbi to use with my 1Gbps internet line, I have setup the main Orbi and the Satellite, however when I test it wit...
Mar 03, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
What devices are you using to speed test wireleslly?
Is your wired speeds to spec? They should be.
I would turn OFF the RBS while wirelessly speed testing with the RBR alone first.
Make sure your wireless device is connecting to the 5Ghz SSID. Can check your connection rates with WiFi Sweet Spots app on your phone or pad. You should see 866Mpbs or something near this...
Ensure WMM is enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
- gabe618Mar 03, 2020Aspirant
Nokia G-240G-C
Yes
Around 10, but I have avoided to use their channels
What devices are you using to speed test wireleslly?iPhone, iPad, Mac
Yes, it can reach up to 9xx mb/s
Enabled already
