mike-armour
Feb 08, 2021Aspirant
Orbi RBK50 Wireless Speeds are Half of Wired
We recently upgraded our cable internet (Xfinity) and had to replace the old cable modem (SurfBoard) with a new Netgear CM1100. With the new cable modem in place, my wireless speeds on my laptop (did...
- Feb 08, 2021
OK. Sounds like you're seeing typical numbers in a "crowded" environment. As you may know WiFi interference is quite common in condo/apartment situations. Especially when lots of folks have powerful routers (like ORBI).
Here's a link to an article describing basic how/why WiFi signals get derated with interference:
One technique is to switch channels from auto to manual and choose a "clearer" channel. Typically Channels 1,6, or 11 for the 2.4 gHz. The 5 gHz channels have a different division scheme. Here's another link to an article regarding channel settings to try:
The issue with your laptop not connecting to the nearest satellite may be simply a false display on the we-based ORBI gui or the Orbi iOS app. This happens quite often as the ORBI system really doesn't report the changeover very quickly. I've seen it take up to 10 minutes to report the swap from an router to a satellite (or vice-versa). Try telling your laptop to "Forget this Network" and reinitialize the WiFi service.
Finally, 2.7.2.104 firmware is getting a reputation of not being the best release for lots of reasons. I'm running 2.7.2.102 and haven't updated yet. I don't plan to anytime soon as my system is running quite well. If it ain't broken, don't fix it.
Good Luck!
tucsontico
Feb 08, 2021Virtuoso
The built-in Speedtest on the ORBI app and web-based GUI are nortoriously inaccurate. A few questions first:
1) What speed did you upgrade to on Xfinity?
2) Have you done a speed check with any third party apps, e.g., Dr WiFI, WiFi Sweetspot, etc.?
3) What wired speeds are you getting if you connect directly to the modem?
4) I noticed you have 2.7.2.104 firmwre installed. Did you power cycle the modem and ORBI system after the install?
Remember that the max speed on 2.4 gHz is 400 Mbps and 866 Mbps on 5 gHz. This driven by the ORBI hardware. To get higher speeds you'll need to upgrade to a WiFi AX router and even then, as the car manufactuers say: "Your mileage may vary." Alot of things can modify your speeds throughout the day and you have little or no control over them, i.e., bandwidth usage by neighbors, channel interference by appliances, etc.
As a point of reference, I have the Xfinity 1 Gbps download/40 Mbps upload and my WiFi speeds come close to the max limits listed above. I live in a semi-rural area where my nearest neighbor is several hundred yards away. I also have a pretty open plan house which allows almost unrestricted flow of 2.4 and 5 gHz signals.
Good Luck!
mike-armour
Thanks for the input - our interior setup is similar to your except for we live in a downtown condo. That said your metrics are what I am expecting to see.
- We upgraded to Xfinity 1Gbps
- So far - I have just been using Speedtest on the computers connected via wire and wireless as well as the speedtest gui. I'll investigate some of the apps you are recommending.
- I am seing 800Mbps to 900Mbps - as I expect to.
- Yes - I power cycled both the router and the satelite.
I had not acounted for the wireless in other units potentially affecting our wifi speed. Our condos are like cement boxes stacked on each other as opposed to a wood and drywall exterior.
I am hoping I have just overlooked a setting on the Orbi.
