mike-armour
Feb 08, 2021Aspirant
Orbi RBK50 Wireless Speeds are Half of Wired
We recently upgraded our cable internet (Xfinity) and had to replace the old cable modem (SurfBoard) with a new Netgear CM1100. With the new cable modem in place, my wireless speeds on my laptop (did...
- Feb 08, 2021
OK. Sounds like you're seeing typical numbers in a "crowded" environment. As you may know WiFi interference is quite common in condo/apartment situations. Especially when lots of folks have powerful routers (like ORBI).
Here's a link to an article describing basic how/why WiFi signals get derated with interference:
One technique is to switch channels from auto to manual and choose a "clearer" channel. Typically Channels 1,6, or 11 for the 2.4 gHz. The 5 gHz channels have a different division scheme. Here's another link to an article regarding channel settings to try:
The issue with your laptop not connecting to the nearest satellite may be simply a false display on the we-based ORBI gui or the Orbi iOS app. This happens quite often as the ORBI system really doesn't report the changeover very quickly. I've seen it take up to 10 minutes to report the swap from an router to a satellite (or vice-versa). Try telling your laptop to "Forget this Network" and reinitialize the WiFi service.
Finally, 2.7.2.104 firmware is getting a reputation of not being the best release for lots of reasons. I'm running 2.7.2.102 and haven't updated yet. I don't plan to anytime soon as my system is running quite well. If it ain't broken, don't fix it.
Good Luck!
tucsontico
Feb 08, 2021Virtuoso
Good Luck!
mike-armour
Thanks for the great links and helpful infomration.
My router is sitting at channel 48 on the 5ghz spectrum (which is what my laptops connect to) and thanks to your post - I used vistumbler to see that there is only one other router usins the exact same channel.
That said - there are a lot of routers close by that are using the other 3 available 5ghz channels.
The Netgear Orbi does not allow for manual DFS entry so I cannot bump the router to one of the higher available channel spectrums.
I have a feeling I am just stuck with what I am getting for my wireless speeds for now unless I do the $$$ for the newer AX router.
Thanks for all the information you shared - it was helpful and I learned something new!
