Zip90
Aug 24, 2020Aspirant
Orbi (RBK50) with a replaced xfinity gateway
i have an Orbi that is up and running in AP mode with an Xfinity gateway. I want to now change the set up and put the gateway in bridge mode and then use my Orbi in Router mode. -Should I make the cha...
Zip90
Thanks for confirming. i assume leave all connections as is, or should is disconnect the Orbi from the gateway when performing the change to bridge mode?
Aug 24, 2020Guru - Experienced User
You can leave them all connected. Be sure you are using the WAN port on the RBR to connect to the ISP modem.
- Zip90Sep 21, 2020AspirantMy ISP gateway is in bridge mode, if I hard wire into the orbi it does pass a connection to the internet but I can not log into the Orbi to change it from Access point to Router mode. Any suggestions? Orbilogin .com and .net don’t connect.
- FURRYe38Sep 21, 2020Guru - Experienced User
Factory reset the RBR with a wired PC connected to the RBR. Use a web browser and walk thru the RBR setup wizard at 192.168.1.1.
