Nitrous16v
Jun 17, 2019Aspirant
Orbi RBK50 with Rbk20 as a satellite?
Hello, I currently have the Orbi AC3000 RBK50 Router and Sat and decided to pick up a used AC2200 RBK20W system (router and wall sat) to try to add on to it with more satellites, Will this work?
CrimpOn
Jun 17, 2019Guru - Experienced User
The wall satellite will connect to the RBR50 Orbi router, but the router that is in the used package cannot be used as a satellite. There are things that you can do with the router, such as set up a separate WiFi network or give it to a friend who has no WiFi at all.
Nitrous16v
Ok thanks thats kind of what i was thinking would be my options
