jasonbb
Apr 16, 2019Tutor
Orbi RBK50 with satellite showing "no internet" when joining network.
Hi all, I have had my Orbi RBK50 and RBS50 satellite since November 2016 and its been great, over the last week and a half its turned to rubbish, I suspect it was after the latest firmware update V2....
- Apr 16, 2019
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.I recommend that you manually re-load v44 and the factory reset and setup from scratch to see if this helps with the issue your seeing. There have been issues with Autoupdate and others seeing bad behavior. Doing a factory reset seems to resolve this for v44.
Re-load the RBS first then the RBR. Reset and setup from scratch.
I saw no issues after doing this process on v44.
jasonbb wrote:
Hi all, I have had my Orbi RBK50 and RBS50 satellite since November 2016 and its been great, over the last week and a half its turned to rubbish, I suspect it was after the latest firmware update V2.3.1.44 because the timing looks to be about right?
What started happening was my iPhones and iPads started dropping off the network all the time, if you go into network setting it says connected to the orbi network but under it says No internet connection, the thing is I have some other iPads and devices on the network with the internet working just fine, one of my Mac laptop's was connected and the other was not so its really weird, the satellite was also dropping off.
A bit over a week ago after some research it said to reset the network and start again. The next day (Wednesday) I had some work going on with my network so he reset the Orbi and re set it up in AP mode as they installed a new Pakedge router with a Control4 upgrade, it worked really well for about 5 days and has now gone to dropping off constantly, I can't connect the satellite now either.
I read it should be set up in router mode but the Pakedge router is now in between the internet connection and the Orbi, please help.
Apr 16, 2019Guru - Experienced User
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307
and Set 20/40Mhz Coexistence to 40Mhz only.
Did you factory reset both RBR and RBS after v44 was applied as setup from scratch?
- jasonbbApr 17, 2019Tutor
Thanks guys, I woke up this morning and everything was working as it should, when I get home I'll apply some of the suggested changes and hope for the best. Thankfully I'm in a low-density residential area so there are only 2 other networks in range.
- FURRYe38Apr 17, 2019Guru - Experienced User
Let us know how it goes...
- jasonbbApr 18, 2019Tutor
Hi, I didn't do a factory reset after the last update on Tuesday night, it was factory reset the previous Wednesday while running .44, all of yesterday it was back and working as it should with the salellite connected, I am going to monitor it and see how it goes over the next few days.
I didn't factory reset it the other night as it was really late and didn't want to have to reset up all my Lifx globes again, if I have further issues I will try another reset.
Thanks for your help.
- jasonbbApr 19, 2019Tutor
Hi Furry, I just made the above changes to the CTS/RTS threshold from 2347 to 2307 but couldn't see the option to set the coexistence to 40 only.
I also did a wireless scan and found no one on channel 6 for 2.4 Ghz so I changed over to that, the 5 Ghz network is on channel 36.
- jasonbbApr 20, 2019Tutor
When I changed it to channel 6 the internet started to drop off again, I put it back to auto and its been all good again.
