Jpol026
Apr 04, 2019Aspirant
Orbi rbk50
I currently have an Orbi rbk50 hard wired to a c6300. The internet speed at my c6300 is over 100mbs. Using the orbi app, the speed on the Orbi is over 100mbs. The speed I am getting at my laptop and ...
Jpol026
I Am using an online speed test . I have the latest firmware. I haven’t yet tried to bridge thec6300 yet. When I first hooked up the orbi there was no speed drop off but I was constantly having to reboot the c6300 which I still do only not as frequently.
Apr 04, 2019Guru - Experienced User
Lets bridge the modem as test again...
- Jpol026Apr 04, 2019Aspirant
There is no wireless bridge tab on my c6300
- randomousityApr 04, 2019Luminary
Log into your C6300, then go to ADVANCED > Administration > Router Mode, select "no," then hit apply. That will put it in bridge mode, though it's not labeled as such in the menus.
I don't know whether that will also disable wifi on the C6300, but you can do it from ADVANCED > Administration > Wireless Settings and uncheck both the "enable wirless gateway radio" boxes (one for 2.4 GHz, and one for 5 GHz), then apply.
After both putting it in bridge mode and disabling wifi, your C6300 will basically just be a cable modem, which is generally the ideal setup if you want to use the Orbi as your router.
- CrimpOnApr 04, 2019Guru - Experienced User
As Jpol028 pointed out, page 75 of the C6300 User Manual, describes the difference between Router Mode "Yes" and "No".
http://www.downloads.netgear.com/files/GDC/C6300/C6300_UM_17Nov2015.pdf
When the C6300 is "only a modem", anything connected to the other LAN ports will not be assigned IP addresses. (Actually, I don't even know if those ports will be turned on.)
