Rocky000007
Aug 13, 2019Aspirant
ORBI RBK50
I am planning to buy an ORBI RBK50. But I do not find the information on how long the disctance may be between the Orbi Router and the Orbi sattelite. And second, how far can I be from my satelite (...
Rocky000007
Ok. That's a good indication of expected distance. And yes I agree it will depend on a number of factors.
I will have to buy test and finetune and hope I get the expected results.
Aug 13, 2019Guru - Experienced User
Hope it works for you!
Keep in mind with mine, I'm running gigabit speeds, using an RBK53 units, and had clear line of sight. Kind of best case scenario. And it only had enough bandwidth to stream music. Just don't want you to have to high of expectations. :) you could potentially add the orbi outdoor satellite at a mid point if you needed more distance.
- Rocky000007Aug 13, 2019Aspirant
Between my master ORBI router and my satelite I will have +/- 30 tot 40 ft (with 2 walls in between. And the distance from the satelite to the location where I will have my remote user device will be be another +/- 60 tot 60 ft. So I suppose it should work fine. (so from Router to user device max 100 ft)
