Walkingbear
Jun 10, 2020Aspirant
Orbi RBK50
Question, does the orbi RBK50-100NAS work with a DSL internet service like say Centurylink.?
Jun 10, 2020Guru - Experienced User
Question is that if Orbi works with the modem. There are two types, modem only and modems with built in routers and wifi:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Orbi systems work with most ISP services and modems or ONTs.
