NRWells
May 13, 2020Aspirant
Orbi RBK52W system
I am looking to purchase a WiFi MESH system for my church. We currently have a Netgear Nighthawk AC1900 but can't get a signal in the sanctuary due to the distance. I was thinking about purchasing the...
May 13, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
NRWells
Ok, but will one satellite talk to the other satellite and then to the router? Is this a true MESH Network? If the signal will not pass from satellite to satellite then this will probably not work for us.
- NRWellsMay 13, 2020Aspirant
Sorry, I just saw the daisychain info. Thanks. Will it do this out of the box or does it require technical setup?
- FURRYe38May 13, 2020Guru - Experienced User
Yes, if you have them Daisy chained in a line, the traffic flow will go from one RBS to the other then to the RBR.
Example of a Orbi AX system in Daisy Chain:
Same thing for Orbi AC.
