PCSP
Aug 09, 2021Guide
Orbi RBK53 - Force autoupdate firmware to v2.7.3.22
Today, I found my router forced update firmware to 2.7.3.22. Is it normal or not? because I use 2.5.1.16 is very stable with my environment It update around 2am GMT+7 Is it normal for this be...
- Aug 19, 2021
I was able to complete this successfully, and downgraded to a stable version firmware.
Here's what I did based on FURRYe38 suggestion, I set Orbi to AP mode first, then connected to a spare router that I have and blocked all ports for Orbi update service (updates.netgear.com or updates1.netgear.com). The auto upgrade finally stopped, everything is back to normal and I'm happy. Thanks everyone who offered to help!
leepaki
Aug 18, 2021Aspirant
I tried to downgrade it to 2.5.1.16 but immediately after it automatically upgraded router and all sats to the newest version, which caused stability issues for me. Very upsetting.....2.5.1.16 has been perfectly stable why force people to upgrade unlesss there's a major security flaw.
Aug 18, 2021Guru - Experienced User
What kind of instability problems are you seeing?
- leepakiAug 18, 2021AspirantYup, I've factory reset everything. The stability issue I'm talking about is clients will randomly show connected to Orbi satellites with full signal strength but no internet access. Sometime disconnecting and reconnecting to the network solves it, but sometimes the issue remains until a full restart is done.
- CrimpOnAug 18, 2021Guru - Experienced User
leepaki wrote:
Yup, I've factory reset everything. The stability issue I'm talking about is clients will randomly show connected to Orbi satellites with full signal strength but no internet access. Sometime disconnecting and reconnecting to the network solves it, but sometimes the issue remains until a full restart is done.Is there a pattern to the devices involved? (same ones? same type of device?)
Full restart refers to
- Restarting the devie
- Powering the Orbi & satellites off and back on
- Doing a Factory Reset
Thanks
Not really any patterns to it, phones, tablet, laptop and streaming boxes in different rooms. Full restart refers to unplug the power of router and sats and power back on.
My problem is really the fact that I can't downgrade the firmware anymore, whenever I manually downgrade the firmware it got automatically brought back to 2.7.3.22 within 5-10 minutes. They also took away the telnet option, so I can't even telnet in to disable auto upgrade.
