PCSP
Aug 09, 2021Guide
Orbi RBK53 - Force autoupdate firmware to v2.7.3.22
Today, I found my router forced update firmware to 2.7.3.22. Is it normal or not? because I use 2.5.1.16 is very stable with my environment It update around 2am GMT+7 Is it normal for this be...
- Aug 19, 2021
I was able to complete this successfully, and downgraded to a stable version firmware.
Here's what I did based on FURRYe38 suggestion, I set Orbi to AP mode first, then connected to a spare router that I have and blocked all ports for Orbi update service (updates.netgear.com or updates1.netgear.com). The auto upgrade finally stopped, everything is back to normal and I'm happy. Thanks everyone who offered to help!
leepaki
Aug 18, 2021Aspirant
Thank you for the suggestions!
I just tried a factory reset on all units, and still got a similar behavior, the wifi connection shows excellent but internet suddenly dropped off during a google meet meeting. I'm going to try your suggestion to run Orbi in AP mode while connecting to an upstream router and block the update service.
leepaki
Aug 19, 2021Aspirant
- FURRYe38Aug 19, 2021Guru - Experienced User
Enjoy. :smileywink:
- PCSPAug 19, 2021Guide
I think no one care about auto update if Netgear upgrade smoothly and stable, reliable ... but It is not ...
Now I back to v2.5.2.4 with blocked auto update too
- FURRYe38Aug 20, 2021Guru - Experienced User
Enjoy.
- ktreynSep 18, 2021InitiateThis solution of not acceptable for the average user. Netgearnetgear needs to fix the problem.
