bmeighan
Dec 15, 2018Tutor
Orbi RBK53 - I need WiFi coverage beyond range of router
I am considering the purchase of the Orbi RBK53 but have the challenge of getting a signal to my guest house's satellite that is beyond the range of the router (about 225'). The guest house is curren...
- Dec 16, 2018
bmeighan wrote:
Thanks for the responses. Just to clarify and/or add more details:
Perhaps I'm confused by the "backhaul" terminology. I read this to be the data from the satellites that is transmitted back to the Orbi router. I understand that through a firmware update the backhaul can be Ethernet wired. But does backhaul also mean that the Orbi router can communicate TO the satellite by way of Ethernet cable? I'm trying to solve for the problem that my guest house is beyond the range of WiFi signal but does have Ethernet to the main house. I also don't want the performance degradation that comes with extenders. So, can the Orbi satellite work in the guest house if it is wired to the Orbi router? (I seem to recall reading that an ethernet wired Orbi satellite cannot be used as an access point.)
Another suggestion provided here was to purchase another Orbi router and connect it in the house in access point mode. While this is an expensive solution, it does sound like it will work (but don't want to if satellite will work).
With regard to the last paragraph, I assume one of my old routers (like an Apple Airport Extreme) can serve as an access point too, right? To configure that as an access point, do I do that through the Orbi software or by using Apple's Airport Utility?
Thanks for the feedback.
Don't read too much into the marketing-speak. Backhaul is bi-directional. You can plug your satellite into Ethernet in your guest house and your guests will access the Internet via WiFi as if they were in the main house. The SSID will be the same as in the main house.
I would not recommend buying a second Orbi system for the guest house, unless the guest house is very large and requires multiple APs to cover it. How large is the guest house? How many floors?
You configure your old router as an access point via your old router's user interface. You do not set it up via the Orbi.
There is confusion about extenders, in part because there are multiple types of extenders. Some extenders simply receive the existing WiFi signal and rebroadcast it on the same channel. These suffer at least 50% degradation in throughput, because they share the same channel. Other extenders take the existing WiFI and rebroadcast it on a new channel. These are better, but they use more channels so are more prone to interference with nearby WiFi systems. Orbi functions similar to the latter extender.
Using your old Airport Extreme in AP mode in the guest house sounds like the best approach here, unless it cannot cover the required area. The Airport Extremes are very good and fast routers. Possibly faster than Orbi.
st_shaw
Dec 16, 2018Master
Yes, if you have Ethernet in your guest house, you can plug-in an Orbi satellite out there and it will provide WiFi to devices in the guest house. This is called wired backhaul. This isn't the most sensible approach, as you would be using an expensive satellite where an inexpensive access point would do the same thing.
If it were me I would probably use the satellite in the main house and put an old WiFi router (or a new inexpensive router) in the guest house and run it in access point mode.
bmeighan
Dec 16, 2018Tutor
- michaelkenwardDec 16, 2018Guru - Experienced User
This myth seems to have gained some traction. I've seen it spouted here earlier this week.
Do not get fooled by ignorant twaddle that you find in a Google search.
What evidence is there that extenders are any worse than putting a router in AP mode, or using an Orbi satellite?
In reality a satellite is an extender. It is just easier to configure and comes with wireless features that do not apply to you and the stretch of your wifi.
The cheapest option would be to buy one box, an extender, and put it on the end of the LAN line to the guest house.
If you buy an Orbi, you get a router and an extender. If you are happy with the current router, apart from making your existing router redundant, what do you gain by using an Orbi satellite?
- ekhalilDec 16, 2018Master
michaelkenward wrote:......, apart from making your existing router redundant, what do you gain by using an Orbi satellite?
Single point of management! He will be able to manage his whole network from one GUI which is -for some- an important advantage! :)
- schumakuDec 16, 2018Guru - Experienced User
bmeighan wrote:
I also don't want the performance degradation that comes with extenders.This myth seems to have gained some traction. I've seen it spouted here earlier this week.
The truth is ... it depends.
El cheepo extenders are made with just two radios, one 2.4 GHz, one 5 GHz band. Then on the Netgear "basic" extenders we can either configure what is called "FastLane", so one radio is handling the link to the primary router, the other is handling three client access. Leaving the band specific limitations alone, there is no other performance degradation. Now when extending both wireless bands, each packet goes over the air, over the same channel(s), twice, with different MAC addresses. Now, here the degradation is obvious - anybody who does say the opposite zzzzz.
Now we have the new Netgear Extender models supporting "mesh" functionality. Here some (not all!) have similar to the Orbi systems three radios. One radio (a 5 GHz one) will be used for creating the uplink to the router or primary WiFi. Ideally, one does configure a higher band channel because these channels allow using much more power in most regulatory domains. The other two radios are serving the client access to the Mesh extender. The degradation here is minimal, mainly the bridging activity does create some additional latency.
- st_shawDec 16, 2018Master
st_shaw wrote:
There is confusion about extenders, in part because there are multiple types of extenders.Spot on there. Another difference not covered in your response is between repeaters used as wired access points or as wifi repeaters.
Wifi repeaters will certainly be less efficient than wired repeaters. But most, it not all, of Netgear's repeaters will operate in AP mode.
By the way, one factor to remember when choosing an Orbi system is that some satellite do not have a LAN port.
Good thinking. Not just a money saver, but using familiar equipment.
And as guest accommodation, does it make sense to go over the top with fancy new hardware?
Splash out on your own kit and give the guests the benefit of the cast offs.
By the way, I see no mention of the base Internet speed. If someone has blindingly fast Gbps internet, then there is no need to bust a gut to get reasonably fast wifi in the guest house. With slow internet you'll want to get as much of it as possible to the remote location.
- bmeighanDec 16, 2018Tutor
Thanks to all for your thorough and understandable responses. Very helpful and now I'm ready to put down the money to get the Orbi system.
- ekhalilDec 16, 2018MasterGood luck :)
