Franzmann
Jul 22, 2019Tutor
Orbi RBK53 - Performance
Dear all, I have installed a RKB53 on the weekend. The performance is pretty slow on the satellite(s). On the router I have a speed of 600Mbit/s and on the Satellites, I have only 160. I ha...
- Aug 04, 2019
Thanks again FURRYe38 CrimpOn ekhalil tucsontico !
I have put now the router on the first floor, use a CAT6-Cable from the modem to the router and the performance is more or less ok.
The router get 600 Mbit/s, the 6210 Wifi stick (6 feet away) get 300 Mbit/s.
On the satellites on the other floors I get 150 Mbit/s.
It´s not what I had await from the Orbi, but I can live with it.
Best regards,
Franz
Jul 23, 2019Guru - Experienced User
How are you speed testing? Wired PC with RBR and RBS or wireless?
What devices are you using to speed test?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. Also having the RBR in the basement is not recommended. This can be problematic as well. It's recommended to have the main base router on the main floor if possible.
Beamforming and WMM should be enabled.
Has a factory reset of the RBR and RBS and setup from scratch been performed yet since the update to v30?
Franzmann wrote:Dear all,
I have tried to check/uncheck already:
- Daisy chain
- Beamforming
- Mu-MiMo
- Fast Roaming
Nothing has helped.
Now I have read, that the firmware 2.3.5.30 may cause problems.
Shall I downgrade to xxx?
Any additional idea what I can do?
Thank you in advance!
Best regards,
Franz
PS: The router is in the basement, the first satellite is in the first floor right (two ceilings in between - 26 feet), the second satellite is in the first floor as well on the left side (two walls - 26 feet). Status of everything is connected in "green".
If you have the RBS placed in a line out from the RBR, then Daisy chain can be enabled. If there is a star formation, then Daisy Chain should be disabled.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Franzmann
Jul 23, 2019Tutor
Thank you very much FURRYe38 and tucsontico !
At first I will make a factory reset. I was not aware, that I have to do it after the FW-Update (2.3.5.30). And I will change the channels if the reset will not have an impact.
May this will already help.
Thank you again for the useful information!
Best regards,
Franz
