Franzmann
Jul 22, 2019Tutor
Orbi RBK53 - Performance
Dear all, I have installed a RKB53 on the weekend. The performance is pretty slow on the satellite(s). On the router I have a speed of 600Mbit/s and on the Satellites, I have only 160. I ha...
- Aug 04, 2019
Thanks again FURRYe38 CrimpOn ekhalil tucsontico !
I have put now the router on the first floor, use a CAT6-Cable from the modem to the router and the performance is more or less ok.
The router get 600 Mbit/s, the 6210 Wifi stick (6 feet away) get 300 Mbit/s.
On the satellites on the other floors I get 150 Mbit/s.
It´s not what I had await from the Orbi, but I can live with it.
Best regards,
Franz
Franzmann
Jul 28, 2019Tutor
Thanks again ekhalil !
I will disable Daisy Chain and I will wait one hour. I will let you know tomorrow the result.
I use a PC with Windows 10 and an Android phone. If you would give me a recommendation, would be great.
Best regards,
Franz
ekhalil
Jul 29, 2019Master
Franzmann wrote:Thanks again ekhalil !
CrimpOn , what apps do you use for wifi scanning on your Android device please? I've never used Androids. :)
- CrimpOnJul 29, 2019Guru - Experienced User
ekhalil wrote:
CrimpOn , what apps do you use for wifi scanning on your Android device please? I've never used Androids. :)My "Go To" Android WiFi analyzer is Wifi Analyzer 3.11.2 by Kevin Yuan. It has "the usual stuff" with graphs, lists of AP's, etc. My favorite part is the list of AP's shows the MAC address and channel of hidden AP's. That's how I know my Orbi is using channels 4and 48, and the hidden backhaul is on 4 and 157. There is another really cool one called WiFi Analyzer (capital F instead of lower case f) by Abdelrahman M. Sid. There's a nice HeatMap that I use on the tablet from time-to-time.
On Windows 10 I am really taken with WiFiInfoView from nirsoft, because waaaaay over on the right it shows the "Country Code" being broadcast.
- FURRYe38Jul 30, 2019Guru - Experienced User
Let us know know how it goes...
- FURRYe38Jul 31, 2019Guru - Experienced User
:smileywink:
- FranzmannAug 04, 2019Tutor
Best regards,
Franz
- FURRYe38Aug 05, 2019Guru - Experienced User
Enjoy. :smileywink:
