Franzmann
Jul 22, 2019Tutor
Orbi RBK53 - Performance
Dear all, I have installed a RKB53 on the weekend. The performance is pretty slow on the satellite(s). On the router I have a speed of 600Mbit/s and on the Satellites, I have only 160. I ha...
- Aug 04, 2019
Thanks again FURRYe38 CrimpOn ekhalil tucsontico !
I have put now the router on the first floor, use a CAT6-Cable from the modem to the router and the performance is more or less ok.
The router get 600 Mbit/s, the 6210 Wifi stick (6 feet away) get 300 Mbit/s.
On the satellites on the other floors I get 150 Mbit/s.
It´s not what I had await from the Orbi, but I can live with it.
Best regards,
Franz
CrimpOn
Jul 29, 2019Guru - Experienced User
On Windows 10 I am really taken with WiFiInfoView from nirsoft, because waaaaay over on the right it shows the "Country Code" being broadcast.
Franzmann
Jul 29, 2019Tutor
Thank you CrimpOn , FURRYe38 , ekhalil !
I will try some of the tools.
btw: My last configuration was already a star with Daisy Chain disabled.
May I get some new information now with the tools.
Best regards,
Franz
- FURRYe38Jul 30, 2019Guru - Experienced User
Let us know know how it goes...
- FURRYe38Jul 31, 2019Guru - Experienced User
:smileywink:
- FranzmannAug 04, 2019Tutor
Best regards,
Franz
- FURRYe38Aug 05, 2019Guru - Experienced User
Enjoy. :smileywink:
