mhiyer
Jul 30, 2021Tutor
ORBI RBK53- satellite pulsing white....
I have an 2-RBS50, and a RBR50. All were running firmware V2.7.3.22. Had a power outage in a storm yesterday that lasted all of 5-10 seconds. Router and satellites rebooted, but one of the s...
- Jul 30, 2021
SUCCESS!!!
so first completely bricked it by pressing reset and holidng it, turing power off, then turned back on. Power LED flashing red. so retried again upload to 192.168.1.1. Worked, and rebooted. Kept flashing white. unplugged ethernet and let it sit. Suddenly, light turned blue. Was able to reconnect to my old satellite and router w/ all the settings. Followed the directions in :
Thanks for your help FURRYe38!
Jul 30, 2021Guru - Experienced User
Did you reset the RBS only or both RBS and RBR?
- mhiyerJul 30, 2021TutorOnly the flashing RBS. Other RBS and RBR were untouched. Nervous to reset those and fry the whole system
- FURRYe38Jul 30, 2021Guru - Experienced User
Is the 2nd RBS listed in the RBRs connected devices page? If it's seen there, remove it using the remove button no the web page. Then reboot the RBR and allow it to come to ready. Turn ON the RBS and when it's pulsating WHITE, hit the sync button on the RBS then RBR. Do this with the this one RBS in same room as the RBR...
by 2nd RBS, do you mean the one that's still working? That shows up in the connected devices. The one that is flashing oringally showed in connected devices. I then removed it from there and hard-reset it to try and sync it as a new satellite. It unfotuantely stayed in the flashing white mode. It never got to the steady white mode to be able to get it to sync with the RBR....
