mhiyer
Jul 30, 2021Tutor
ORBI RBK53- satellite pulsing white....
I have an 2-RBS50, and a RBR50. All were running firmware V2.7.3.22. Had a power outage in a storm yesterday that lasted all of 5-10 seconds. Router and satellites rebooted, but one of the s...
- Jul 30, 2021
SUCCESS!!!
so first completely bricked it by pressing reset and holidng it, turing power off, then turned back on. Power LED flashing red. so retried again upload to 192.168.1.1. Worked, and rebooted. Kept flashing white. unplugged ethernet and let it sit. Suddenly, light turned blue. Was able to reconnect to my old satellite and router w/ all the settings. Followed the directions in :
Thanks for your help FURRYe38!
Jul 30, 2021Guru - Experienced User
Can you upload to 192.168.1.250 or access it's web page here?
mhiyer
Jul 30, 2021Tutor
SUCCESS!!!
- FURRYe38Jul 30, 2021Guru - Experienced User
YAY.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. :smileywink:
