JBRinSJC
Apr 16, 2019Aspirant
Orbi (RBK53) AC3000 Tri-band WiFi System randomly blocks websites
The Orbi router is randomly blocking websites.
Orbi AC3000 Tri-band WiFi System (RBR50) - Router Firmware Version V2.3.1.44
Issue is affecting a laptop running MacOS v10.13.6 & an iPad running i...
Apr 17, 2019Guru - Experienced User
What other security tools do you have in place?
I would factory reset the RBR and set up from scratch. Skip installing any Circle or enabled parental controls for now.
JBRinSJC wrote:
The Orbi router is randomly blocking websites. Orbi AC3000 Tri-band WiFi System (RBR50) - Router Firmware Version V2.3.1.44 Issue is affecting a laptop running MacOS v10.13.6 & an iPad running iOS v12.2 We've tried using Safari & Chrome browsers on each - same message shows NetGear router blocking access. There are no settings on the router that show any blocked websites. The issue started when NetGear first offered a promo deal on the NetGear Armor subscription service. We have not purchased it - do not need it. We have other security tools already in place.
