Jerky
Apr 12, 2018Aspirant
Orbi RBK53 and using Circle
I'm having problems using the Circle app with my new Orbi AC3000, RBK53 system. When I try to open the Circle app on my phone it states that "your firmware is out of date." I then try to update the f...
Apr 12, 2018Guru - Experienced User
Try installing updated FW manually? You can see if your model has v2.1.3.4 available. I think it is...
Use IE11, or FF browser to update the router and satellite after downloading the FW update files.
Jerky
That worked. Thank you. Have a great night.
