049xxv
Jun 03, 2018Aspirant
Orbi RBK53 cannot maximize the wifi bandwidth of Samsung Galaxy S7 at 5GHz
I am using Netgear Orbi RBK53 and Samsung Galaxy S7, and there is a problem. S7 can ultilize 5GHz bandwidth up to 867Mbps, which has been proven by working with routers of other vendors. But when S7 connects to Orbi, the bandwidth is 433Mbps or lower. I have tested the bandwidth near the router, and obviously it doesn't work. Changing the region, changing the channel and changing other settings don't work, either.
1 Reply
- 049xxvAspirant
It's solved. I have confirmed that the "MU-MIMO" feature of various routers is not compatible with Samsung Galaxy S7 (Edge). One must uncheck the box of "MU-MIMO" in the settings to ensure that devices with "2x2" antenna reach full bandwidth.
