Peterk81
Apr 17, 2020Aspirant
Orbi RBK53 constant disconnects and slowness
I recently purchased the ORBI RBK53 from costco and it has been nothing but problems since I've owned it. I work from home and it is important to be available and connected via vpn to work. I get dis...
Apr 17, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
25 feet maybe too close.
Please try a factory reset and setup from scratch with the RBR and RBS.
- Retired_MemberApr 17, 2020
waste of time
- Peterk81Apr 17, 2020Aspirant
Thank you for the reply. My ISP is charter and I currently have the Spectrum E31T2V1 cable modem. I have the 200mbps plan
I performed a factory reset yesterday and also have the following settings set:
ipv6 disabled
Upnp disabled
armour disabled
daisy chain enabled
Beam forming enable
MIMO enabled
Wmm enabled
2.4 channel 1 & 6
5 channel 48
Changed domain name server to 8.8.8.8
I have tried distances between 25-40 feet. There was no improvement but the further away, the slower the speeds. I am sure there are other settings i tried that i have not listed
- FURRYe38Apr 17, 2020Guru - Experienced User
uPnP should be enabled.
So are you getting disconnects with just the RBR or with the entire system?
Peterk81 wrote:Thank you for the reply. My ISP is charter and I currently have the Spectrum E31T2V1 cable modem. I have the 200mbps plan
ipv6 disabled
Upnp disabled
armour disabled
daisy chain enabled
Beam forming enable
MIMO enabled
Wmm enabled
2.4 channel 1 & 6
5 channel 48
