Peterk81
Apr 17, 2020Aspirant
Orbi RBK53 constant disconnects and slowness
I recently purchased the ORBI RBK53 from costco and it has been nothing but problems since I've owned it. I work from home and it is important to be available and connected via vpn to work. I get dis...
Apr 17, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
25 feet maybe too close.
Please try a factory reset and setup from scratch with the RBR and RBS.
Retired_Member
Apr 17, 2020waste of time
