Peterk81
Apr 17, 2020Aspirant
Orbi RBK53 constant disconnects and slowness
I recently purchased the ORBI RBK53 from costco and it has been nothing but problems since I've owned it. I work from home and it is important to be available and connected via vpn to work. I get dis...
Peterk81
Thank you for the reply. My ISP is charter and I currently have the Spectrum E31T2V1 cable modem. I have the 200mbps plan
I performed a factory reset yesterday and also have the following settings set:
ipv6 disabled
Upnp disabled
armour disabled
daisy chain enabled
Beam forming enable
MIMO enabled
Wmm enabled
2.4 channel 1 & 6
5 channel 48
Changed domain name server to 8.8.8.8
I have tried distances between 25-40 feet. There was no improvement but the further away, the slower the speeds. I am sure there are other settings i tried that i have not listed
Apr 17, 2020Guru - Experienced User
uPnP should be enabled.
So are you getting disconnects with just the RBR or with the entire system?
ipv6 disabled
Upnp disabled
armour disabled
daisy chain enabled
Beam forming enable
MIMO enabled
Wmm enabled
2.4 channel 1 & 6
5 channel 48
