kevin_gee
Jul 01, 2020Aspirant
ORbi RBK53 Dropouts & Logs
So, unfortunately I paid a lot of money for this rbk53 system. It worked great for about 2 weeks and then nothing but dropouts and resets later I would really like a solution. I am using virgin m...
Jul 01, 2020Guru - Experienced User
If your ISP modem already has a built in router, then this could be a problem. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
