kevin_gee
Jul 01, 2020Aspirant
ORbi RBK53 Dropouts & Logs
So, unfortunately I paid a lot of money for this rbk53 system. It worked great for about 2 weeks and then nothing but dropouts and resets later I would really like a solution. I am using virgin m...
kevin_gee
ive now got my home hub 3 router now set as a modem and the orbi as router. it too many many attempts from the oribi to see the internet, and eventually it worked, took about 20 retrys. I knew I had it setup correctly. So it eventually connected.
I'll see how this goes for a while and monitor
I do have an r7800 x4s but I dont want to use the orbi as an AP but then again the qos is good, I dont think the orbi uses it but I'll see how it goes with throttling before i make anymore changes
Jul 01, 2020Guru - Experienced User
Sometimes you have to turn OFF the modem and RBR for 30 seconds then back on with the modem first, then the RBR lastly.
Glad you got it going finally. Let it run for a while and see. You should be ok.
- kevin_geeJul 01, 2020Aspirant
i cant work like this, I think I'll have to go back to continual disconnects.
I plug up my homeplugs to the orbi and it doesnt even recognise any of them even connected. I connect sky cable, and it says sky wired. I connect homeplug and nothing.
What are NG thinking making pish like this ?
