kevin_gee
Jul 01, 2020Aspirant
ORbi RBK53 Dropouts & Logs
So, unfortunately I paid a lot of money for this rbk53 system. It worked great for about 2 weeks and then nothing but dropouts and resets later I would really like a solution. I am using virgin m...
CrimpOn
Jul 01, 2020Guru - Experienced User
kevin_gee wrote:So, unfortunately I paid a lot of money for this rbk53 system. It worked great for about 2 weeks and then nothing but dropouts and resets later I would really like a solution.
I'm no tecchy, so I really need to know where to find the logs for the orbi system so I know what is at fault, the orbi or my internet connection.
Netgear provides 90 days of "complimentary support" with the purchase of an Orbi system. There is a link on the product registration page to "Contact Support". Since you paid for it, that is one possibility to consider.
Orbi "logs" are not part of the Orbi "app" interface. There is a debug facility on the Orbi web interface which produces tons of information. Whether any of the data is relevant to your situation is a question better addressed by Netgear support. I just produced a debug file from my Orbi while researching a different issue, and the quantity of data is overwhelming.
kevin_gee
had this crap for over 90 days unfortunately
- FURRYe38Jul 01, 2020Guru - Experienced User
So try the modem in router mode and set the Orbi for AP mode and see how it goes.
Contact NG support for additional help and information.
Good Luck.- kevin_geeJul 02, 2020Aspirant
So, im back to plain old drop outs again.
That was a full 12 hrs I suffered with this yesterday. Finished at 4am as both myself and partner are working from home we need a network connection. Took about 3 hrs for it to go back to normal, the orbi wouldnt connect, eventually it did. I'm scared if it ever has to have a reboot. Surely I can have this trouble from other 'Mesh' systems for half the cost. ?
My ISP router always had its wifi turned off, both 2.4 and 5g. There's no interference.
I'm going to stick with this for now, once things are less busy here I'll send this crap back to amazon and get something just as crap and save money.
I do appreciate the help though, thanks for that.
- FURRYe38Jul 02, 2020Guru - Experienced User
Good Luck.
