Orb1Man
Feb 08, 2018Aspirant
Orbi RBK53 Ethernet / wifi satellite connection
I've purchased an Orbi rbk53 (2 Satellites). Can I use Ethernet backhaul connect from the Router (RBR50) to Satellite 1 (RBS50) and Wifi connect from the Router to Satellite 2 (RBS50). I can not wi...
sunildax
Feb 11, 2018Star
Please check if the router and SATs are upgraded to FW 2.1.2.18
This FW is by far the most stable. Lots of posts here on how stable it is with people claiming no reboot for almost 3 weeks.
I use the RBR50 in AP mode and the RBS50 is connected with a wired backhaul.
I would recommend setting up one router at a time. Start with the wired backhaul first with the second SAT powered off. Once you have stabilized the wired SAT, then power on the SAT which you want to be wireless. So the setup while the SAT is in the same room as the router. Once the connection is stable, move it to the desired location. Be ready to allow repositioning which you can ascertain when the LED ring remains a steady blue color.
Test the wireless SAT connectivity by doing speed checks on a connected device (mobile phone). Use the Ookla app for the speed test.
Orb1Man
Feb 11, 2018Aspirant
That's great advice, I will try that.
Many thanks!
Many thanks!
