dalnew
Feb 12, 2018Tutor
Orbi RBK53 ethernet backhaul issue
I have upgraded my Orbi router and satellites to the latest firmware (2.1.2.18) and I am seeing some weird behavior with regard to what's shown on the "Connected Satellites" section of the orbi route...
MillerHouseTX
Jun 07, 2018Tutor
I have this exact issue... Please help
- FURRYe38Jun 08, 2018Guru - Experienced User
MillerHouseTX wrote:
I have this exact issue... Please help- Flash008Jul 27, 2018Luminary
Well, if it helps anyone sleep better…
20 year I.T. nerd who just jumped on the Orbi train. Like many, I wanted Ethernet Backhaul and had problems.
I DO USE CISCO MANAGED SWITCHES!!!!
After a few hours of troubleshooting I found my problem.
FIRST…If you don’t understand STP (Spanning Tree Protocol)…..then go read…I am not teaching STP tonight….It’s too late and I am tired.
I can confirm Orbi (and Orbi Pro) are using STP (NOT RSTP)…What a joke…who doesn’t support Rapid STP today…LOL…I managed to confirm this by changing my STP ID (Prioroty) on my Cisco switch to 61440…AND GUESS WHAT???? My root bridge ID (AKA: MAC) changed to the ORBI ROUTER….This is only possible if Orbi is running STP and has an ID higher or the same ID as my Cisco. I typically use ID=0 for my Cisco….Which would explain the problem.
Orbi wants control of STP…..It’s that simple….And Netgear offers no method to change ANY STP settings in their code….Hence your managed switches with STP will go to WAR with Orbi and make Ethernet backhaul nearly impossible.
STP rules my friends…Highest STP ID WINS! It’s just how STP is designed.
Furthermore. If you have a managed switch with a higher STP ID (Priority), then every time Orbi attempts to change (update) the typology (such as switching from WIFI to Ethernet backhaul)….GUESS WHAT…..Can you say “discarding/blocked state”.
What’s more FUN…is the Satellite that is connected via ethernet now has its port set to discarding….This is forcing the satellite to use its WIFI backhaul and my Cisco switch is “discarding all packets from that Satellite Ethernet port.
So now….My ONLY option is to….DISABLE STP on my satellite port. This will allow a LOOP. BAD!!!!
But I must put my TRUST into Netgears hands….and hope the code is smart enough to send all client MACs down the ethernet port and not the WIFI port…God knows if my switch STP sees MACs coming from both the Sat ethernet port and the main Orbi router ethernet port (which will happen if clients MAC take both paths via the WIFI backhaul….)….well….we network nerds know what happens then….LOOP…DISGARD all packets….or broadcast storm (should you disable STP) and your entire LAN crashes…..
So, my config I am rolling with is….STP enabled on my Cisco (only STP, not RSPT…Orbi doesn’t support RSTP…STUPID)…..
Disable STP on Satellite ports….This allows MACs to take both ethernet and WIFI backhaul paths.
Insure STP is enabled on the Main Orbi router ethernet port. AP mode or Router mode, doesn’t matter. This will protect you from a packet loop crash.
This config will allow your Orbi Sat to ALWAYS be able to communicate with the main Orbi regardless of STP status. After that…its entirely up to the Orbi Sat to establish its ethernet backhaul….a reboot will surely be required as the Orbo code is REALLY STUPID…..My GUESS is the Orbi detects Ethernet during boot and if it can contact the Main Orbi via Ethernet…then it prefers that connection and will switch-off the 5Ghz backhaul which I confirmed by logging into the Sat directly and observing the 5Ghz backhaul DISBALED when using ethernet…
But, if that Ethernet drops and Orbi Sat can’t communicate with the main Orbi (due to STP blocking, power outage or other reasons..)…it rolls back to 5Ghz backhaul and doesn’t seem smart enough to switch back to ethernet….without another reboot. Again…stupid….
Hoped this helped those with managed switches and using Orni with ethernet backhaul.
Surely Netgear could have done this better….
An EASY fix would be for Netgear to allow STP to be DISABLED and let our managed switches handle STP….
And really…RSTP would fix this easily….Why are you not using RSTP?….Do you have any idea how long it takes classic STP to update topology when connections change….REALLY….??????
I spent 10 minutes looking at my RSTP stats…then it hit me….My Orbi ports shows STP….NOT RSTP mode. I tried to force an RSTP migration…But nope…Your Orbi’s kicked by STP mode back to classic….LAME!!!!
Orbi is using STP ID 32768 (STP Default Priority).
