mohammed997
Sep 27, 2020Aspirant
Orbi RBK53 internet connection is not stable
Hello My RBK53 orbi is facing internet unstability issue. usuaaly during the day it disconeectets three to four times. The issue is the main main router that the orbi devices is connected with has n...
Sep 27, 2020Guru - Experienced User
Built in router here by chancr? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Has a power OFF of the ISP modem, RBR and RBS for 30 seconds since last FW update been performed?
