caremd99
Jul 24, 2019Aspirant
Orbi RBK53 not showing all devices
I am using V2.3.5.30 and I am missing at least 1 connection in the GUI list. I know the connection is working because I can http into the connection’s IP address.
- Jul 24, 2019
caremd99 wrote:
I am using V2.3.5.30 and I am missing at least 1 connection in the GUI list. I know the connection is working because I can http into the connection’s IP address.It would help if you identify the device that is missing from the Attached Devices information.
I experience the same phenomenon with regard to my Nest Thermostat. It is definitely "on the network" because I can open the smartphone app, display the current temperature, change the temperature, etc. What I discovered after some testing is that Orbi only knows a device is "on the network" when the device generates packets. After a few minutes of no traffic, the device disappears. I "proved" this by watching the Attached Devices web page as I opened and closed the smartphone app. Thermostat not there. Open app. Thermostat appears. As long as the app is open, the thermostat remains on the display. Close the app, and after a few minutes the thermostat disappears.
CrimpOn
Jul 24, 2019Guru - Experienced User
caremd99
The device is an Enphase Envoy and I suspect it acts quite similar to Nest Thermostat in the fact that it only sends data once every 20 min or so.
