SW_
Apr 28, 2019Prodigy
ORBI RBK53 Region Change
If you'd like to save some bucks and buy Orbi from Costco and bring it home outside the US, but you want to make a region change from North America to your region, try this:
1. Login to Orbi/de...
Mike_D_il
Sep 21, 2019Guide
For months I couldn't find a solution to my Raspberry Pi (Model 4) disconnecting reguarly from the AC3000. (To be more accurate - it was staying connected to the Orbi wifi, but somehow, had no access to the Internet). The Orbi was purchased in Canada, but the Raspberry Pi came from Europe. I repeatedly tried adjusting the Localisation settings on the Pi - but to no avail.
Then I came across this post. Although it specifies the RBK53, I decided to try it on my RBK50.
It's now 48 hours since I changed my Orbi to Europe and I'm delighted to see that I'm still attached to the Internet. Many thanks.
If someone has an explanation about what's going on here, I'd love to hear it. If my Pi is set to US, and my Orbi to North America, why would it repeadedly disconnect? Why would placing them both on Europe make a difference?
michaelkenward
Sep 22, 2019Guru - Experienced User
My guess, and it is no more than that, is that the communications standards are different.
Stuff sold in Europe is not locked to a region. The browser graphical user interface (GUI) lets us change it, with a dropdown that covers most of the world.
In the USA they lock them down. (I got sent one from the USA.) This is probably because the FCC, or whoever sets the rules, does not allow the use various wifi bands and perhaps other things. So Netgear, and others, may just be following the law.
