SW_
Apr 28, 2019Prodigy
ORBI RBK53 Region Change
If you'd like to save some bucks and buy Orbi from Costco and bring it home outside the US, but you want to make a region change from North America to your region, try this:
1. Login to Orbi/de...
Oct 21, 2019Guru - Experienced User
192.168.1.1/debug.htm then select the check box next to Enable Telnet to enable it. You have to enable it first to access telnet.
BillTh wrote:Please excuse a couple of basic questions regarding how to telnet into Orbi. I've enabled telnet access and tried to access the router via ssh on my Mac. Mac no longer has telnet included with its OS.
- Do I need to use telnet, or should ssh work?
- If ssh works, would the commands be the same?
- In either case, what do I need to enter on the command line in Mac terminal to proceed? WhenI enter ssh admin@[ip address] access is denied.
Thank you.
Bill
CrimpOn
As far as I can tell, Orbi does not support ssh.
