SW_
Apr 28, 2019Prodigy
ORBI RBK53 Region Change
If you'd like to save some bucks and buy Orbi from Costco and bring it home outside the US, but you want to make a region change from North America to your region, try this:
1. Login to Orbi/de...
Mike_D_il
Oct 22, 2019Guide
Hi Bill,
From my recollection it was pretty simple and I didn't need to add anything to my MAC. You should use Telnet, not SSH. Take a look at this:
https://www.siteground.com/kb/mac_terminal_telnet/
Mike
BillTh
Oct 22, 2019Aspirant
Thanks Mike. Unfortunately, Apple has removed Telnet from its OS in recent releases. Here's a link that talks to that and provides options to install Telnet. I went with the first option.
Bill
