SW_
Apr 28, 2019Prodigy
ORBI RBK53 Region Change
If you'd like to save some bucks and buy Orbi from Costco and bring it home outside the US, but you want to make a region change from North America to your region, try this:
1. Login to Orbi/de...
simzhewei
Nov 15, 2019Aspirant
HI, this no longer seems to work. I tried with my router firmware is V2.3.5.30.
I telnet succesfully and change the file but when I login it doesn't give the option to change region under advanced wireless.
- michaelkenwardNov 15, 2019Guru - Experienced User
Can you explain exactly what you did?
What do you mean by "change the file"?
My memory is that this is what I did:
- simzheweiNov 15, 2019Aspirant
I enabled telnet and telnetted in,
I used both:
- root@RBR50:~# rm /tmp/firmware_region
- root@RBR50:~# echo WW > /tmp/firmware_region
and check the result, it should return WW
- root@RBR50:~# cat /tmp/firmware_region
also
artmtd -r region
The region number is: 0x0002
REGION: WW
I logged back into the router and went to the advanced wireless and refreshed. This is what I see:
- CrimpOnNov 15, 2019Guru - Experienced User
Region is on the Advanced Tab->Advanced Setup->Wireless Settings
