SW_
Apr 28, 2019Prodigy
ORBI RBK53 Region Change
If you'd like to save some bucks and buy Orbi from Costco and bring it home outside the US, but you want to make a region change from North America to your region, try this:
1. Login to Orbi/de...
SW_
Nov 15, 2019Prodigy
simzhewei wrote:I enabled telnet and telnetted in,
I used both:
- root@RBR50:~# rm /tmp/firmware_region
- root@RBR50:~# echo WW > /tmp/firmware_region
and check the result, it should return WW
- root@RBR50:~# cat /tmp/firmware_region
also
artmtd -r region
The region number is: 0x0002
REGION: WW
I logged back into the router and went to the advanced wireless and refreshed. This is what I see:
Just tried this on the latest FW version (v2.5.0.40) and it's still working for me. Check out the attached picture.
simzhewei
Nov 15, 2019Aspirant
Thank you for the screenshot. I realised my firmware wasn't up to date. Though I had used the app to update it, it was still only on version 2.3.5.30. Having said that even after manually updating to the latest firmware (2.5.0.40) I still don't see region setting changes. In fact my advanced wireless settings menu looks much more basic than the screenshot you have provided.
Please see mine attached. If any ideas how to fix this, please let me know! BTW just checking but I am using RBK53, I'm assuming that this is exactly the same model for everyone?
Cheers,
- michaelkenwardNov 15, 2019Guru - Experienced User
No, but the instructions are generic, for all models. Just change the instructions.
simzhewei wrote:BTW just checking but I am using RBK53, I'm assuming that this is exactly the same model for everyone?
Cheers,
- CrimpOnNov 15, 2019Guru - Experienced User
You are still on the wrong screen. On the Advanced Tab, go down to the bottom, to Advanced Setup, then Wireless Settings.
- Mike_D_ilNov 16, 2019Guide
I successully did it on my 2.3.5.30 this morning.
